codec problems
  • KimOnTheRadio
    • Feb 2009
    codec problems
    I am have the worst time trying to load in a wma codec. I have XP and I downloaded the pro10 codec for XP. Everytime I try load the codec I get
    "Error whilst running 'C:\Program Files\Illustrate\dBpoweramp\dBConfig.exe' in a box with an "ok" to click. I click 'ok' and the finished box for loading a program is under. I still cannot convert.
    1. What do I do?
    2. Does this codec have any kind digital license conflicts attached?
    Re: codec problems
    You need to install dbpoweramp music converter first, then the wma codec to the same folder.
      Re: codec problems
      Also, make sure you are using dMC r12 or higher. See below in my signature if you need to find your version.
