Real audio files - problem
  • savagcl
    • Aug 2004
    • 439
    Vista 32/64 bit system
    dbPoweramp 13.1 registered
    Real Alternate 1.9.0 (latest)
    encoderreal audio release 5
    decoder directshow decoder
    directshow.dll
    DSExt = // Add supported DirectShow file type extensions, type only one extension per
    // line (replace .xyz below), re-run 'dMC Configuration' after adding new, for example:
    // .ac3
    // .abc
    .ra
    .rm
    A search gave me some pointers but they didnt work for
    me.
    I can not tell if the ra, rm was added to the configuration because the window isnt resizable.
    Converting gives me the same problem i see others posting
    about. A 200+ converting speed and a 30kb file, 960 milli-
    second length. For winamp and WMP, the file is so short,
    i can't tell if it plays or not but obviously, something is
    wrong. The original file does play in windows media classic.
    I have dbP 13.1 on drive C and dbP 12 on a different
    HD (XP) (hot-pluggable HD) neither version will work.
    Confused,
    savagcl
  • savagcl
    • Aug 2004
    • 439
    Re: Real audio files - problem
    Note: the old Aux program will do the conversion to a wav file
    correctly and it will playback OK.
    savagcl
      To clarify, do the original Real Audio files play in WMP?
      • savagcl
        • Aug 2004
        • 439
        No, neither .ra or .rm will play in WMP.
        In 13.1 folder:
        Decoder folder shows:
        DirectShow.dll, DSExt.
        wma.dll, wma v9.1.dll, wma v9.dll
        Encoder folder shows:
        Real Audio (Helix).dll (Rel 5 Using Helix SDK v11 dated: 22/1/2007.)
        wma10.dll
        The output file only shows as a 30kb wav file with a
        length of 960 milli-seconds.
        WMP results are the same as winamp.
        thanks for the help,
        savagcl
        • savagcl
          • Aug 2004
          • 439
          Also the .ra and .rm extensions do show up in the directshow
          decoder (from the configuration program)
          savagcl
