Aux Input Problem
  • ketch40
    • Jan 2003
    Aux Input Problem
    When recording stereo L P,s with db Aux Input no matter what I select or do the selection is converted to mono I know good stereo is getting to the sound card I've tried every thing I can think but I mus have over looked something
    • 46229
    You might be using the Microphone input which is mono only. Or the compression format used is mono, check this by Record Menu >> Record with options.
    • ketch40
      • Jan 2003
      I didn't know about record with options Allis now well many thanks
