Help! Problems with AMG/PerfectMeta access in R13.1
  • Christine Tham
    • Oct 2008
    Hello
    I recently purchased and downloaded R13.1. This was an upgrade from R12.4. Everything, including AMG access was working fine in R12.
    I upgraded it under Administrator account in Vista Ultimate, and everything is also fine.
    However, when I log in as another user (my "normal" login name - let's call it X) AMG access is shown as <30 days left, instead of >300 days.
    This login name (X) also has Administrator access on the local machine.
    I have tried everything - including reinstalling R13.1 under the "X" account name, turning UAC on and off.
    I have even tried downloading and running ActivateAMG.exe, but it says my order number is invalid (even though this is the same order number I use to successfully initiate registration retrieval - and I am making sure I'm typing exactly the same number).
    I am now thinking of deinstalling and reinstalling everything, and running the reset utility, but I don't want to lose my settings.
    Is there any way I can have AMG Access under both Administrator and my normal login name? I hate to have to log off and login as Administrator just to run dbPoweramp!!!
    Re: Help! Problems with AMG/PerfectMeta access in R13.1
    Are you using the order number of the R12 purchase to activate AMG? upgrades do not include new AMG licenses?
    • Christine Tham
      • Oct 2008
      Took me a while, but I finally found the order number for my AMG renewal, entered that into AMGActivate, and everything now works.
      Thanks a lot for the tip.
