Problem with Batch Converter
  • dudeymon
    • Sep 2008
    Hi all,
    I'm new to the batch converter program.
    I'm getting an Error Creating WMA Profile message when I try to convert WAV to WMA using the batch command. But I can convert the same file just fine using Windows Explorer & right-clicking to "Convert To".
    My command is: "c:\program files\illustrate\dBpoweramp\coreconverter.exe" -infile="F:\A Wave Files\Inwave.WAV" -outfile="F:\Zune Tunes\testtt.wma" -convert_to="Windows Media Audio 10" -codec="Windows Media Audio 9.2" -settings="VBR Quality 100, 44 kHz, 2 channel 16 bit VBR"
    I get the following: Warning: RIFF chunk has uneven databytes, is non-compliant RIFF, and Warning: 'RIFFSizeLeft != FileSizeLeft' must be extra data on end of file, and Error Creating WMA Profile
    Now, truth be told, I did mess with the input WAV file using VisualBasic, and it probably is non-compliant. But it plays fine on all players, and dbpoweramp converts it just fine when I do not use the batch converter.
    So, is there an option I can use to tell the program to ignore any RIFF compliance errors????
    Dudeymon
    Re: Problem with Batch Converter
    So the file that dMC is able to convert just fine to the same settings via the GUI won't convert by command-line?
    • dudeymon
      • Sep 2008
      Exactly. Input file is 96K24b 2-channel wave. I want to go to WMA lossless 44.1K16b 2-channel. Works fine using the GUI. Batch command does not.
        Are you sure that's the right command-line? See this thread for some tips, though do note the thread is in relation to scripting: http://forum.dbpoweramp.com/showthread.php?t=17347
          • 46139
          Does your command line work with a normal wave file?
          • dudeymon
            • Sep 2008
            Re: Problem with Batch Converter - fixed - User Error
            Spoon's question got me to try a compliant WAV file. It failed as well. Then I changed to a lossy codec & it worked. Then I carefully retyped the lossless command and voila - then it worked!
            I still can't figure out where I had the typo - but I'm convinced the problem was somewhere the text was not exact.
            Sorry to trouble you guys.
            :blush:
