installation problems
    hi guys
    everytime i try to install the music converter software i get a msg saying "unable to run musicconverter.exe" at the end of it and nothing seems to have been installed
    im running xp pro and have media player 9 installed
    any clues?
    thanks
    lauren
    • 46228
    Sounds like you haven't installed the Music Converter, just a Codec. Or if you have make sure it is all installed to the same place.
      yup i did
      and i re-installed twice to make sure
      same error
        • 46228
        Very odd, try downloading the new Release 10 Beta 2 or 3 from the beta section of this forum.
