24-bit 96 kHz to 16-bit 44 kHz flac
  • dylanremaster
    • Oct 2007
    • 38
    Hi I just wonder if it is the correct way to create 16-bits flac files from 24-bits flac files So I can burn them as CD audio
    like this
    24bit flac --> 16 bit Wav --> 16 bit flac
    I don't need to make anything else ?
    //C
    • 46370
    Re: 24-bit 96 kHz to 16-bit 44 kHz flac
    You can go FLAC to FLAC if you use the DSP effects Bit depth and resample
    • didbox
      • Aug 2007
      • 8
      Hello,
      I want to downsample some FLAC files from 96 Khz to 48 Khz. I tried two ways to do this downsampling:
      - FLAC to FLAC conversion with the resample DSP effect
      - FLAC to WAV conversion with option Uncompressed 48 Khz and then WAV to FLAC conversion
      I noticed that the result FLAC file has a different size according to the choosen method. Is it normal?
      Thank you!
        • 46370
        Wav might not have all the ID Tags of the FLAC >> FLAC.
        • LisaRCT
          • May 2003
          • 21
          I have a related question:
          When downsampling a 24/96 flac to 16/44.1 flac, does dbPower simply truncate the last 8 bits, or does it use a more complex conversion including dither?
          Imagine . . . . .
            • 46370
            Truncate, dither has yet to be re-added to R13.
            • LowWater
              • Mar 2010
              Same question as LisaRCT back in 2009 - now that we have the dither option, is it advisable to use when downsampling 24/96 to 16/44.1 flac? The dBpoweramp Music Converter DSP (bitrate) menu advises one to do so.
                • 46370
                Yes if you have the option, using dither going 24 bit >> 16 bit is a good option.
                • LowWater
                  • Mar 2010
                  Thank you Spoon. I apologize for drifting off the OP's topic, but does anyone know if Cowon's up to date firmware (specifically for their J3 model) is capable of recognizing and playing hi-definition 24 bit FLAC files?
                  • gandlz
                    • Jun 2016
                    scenario:
                    input=24bit wave including 16bit dither
                    output=16bit wave
                    no sample rate conversation
                    does it just truncate or perform rounding and then truncate?
                    Is there a difference between using the bit-depth DSP fixed to 16bit and using no DSP? I know the DSP can add dither but it's not needed in this case.
                    Gandlz
                      • 46370
                      Rounding then truncate.
                      • gandlz
                        • Jun 2016
                        so using the bit-depth DSP does not affect this behavior and therefore makes no sense in this case?
                          • 46370
                          They are the same.
                          • gandlz
                            • Jun 2016
                            Thank you very much!
                            • Griff Dixcy
                              • Nov 2010
                              • 32
                              How do I resample? Is there a DSP to set sample rate?
