Problem to Convert WaveTo Wave
  • AlbertoCh
    • Jul 2008
    Members of the forum:
    I have a problem when you convert Wave to Wave. the problem that is when I try to convert a file of more than 64 kilobytes, the application fails.
    anyone have any idea that may be happening?
    thank you very much
    Re: Problem to Convert WaveTo Wave
    What is the exact error?
    Are you converting to or from compressed WAV files?
    • AlbertoCh
      • Jul 2008
      the specific problem and not know what that is an internal problem of CoreConverter.exe but if that is where files are larger than 64 KB application falls.
      I have the idea that internally it is a variable overloading
      but I want to confirm it with other people
      Another possibility is that this failing codec
      but the file is playable without problems
      • Wayne
        • Aug 2002
        • 1254
        What are the bit and sampling rates of the original wav file?
        Can you perform a test conversion?
