Problem with dbpoweramp batch convert
  • erwin
    • Jun 2008
    Hi all
    since I upgraded to version 13 I detected a problem in the batch convert utility which not appeared on the previous version: some of my (deeply nested) directory trees are completely missing there
    Here is the explorer view
    and here the result in dbpoweramp batch convert
    Can somebody help me?
    Erwin
    Re: Problem with dbpoweramp batch convert
    It looks like your R: drive is an exterenal HDD, is that correct? Or is it a network drive?
      • 46169
      We no longer show hidden folders, you migh be able to get there through the 'Documents' at the top.
      • erwin
        • Jun 2008
        Hi Spoon
        the Folder was marked as "hidden" - this was the problem. Thanx a lot for your fast reply
        Erwin
