CoreConverter.exe problem with LAME + network drive
  • Pepin
    • May 2008
    When encoding files from a network drive using LAME, an error will be generated ("CoreConverter.exe has encountered a problem") each time a file is encoded.
    This only occurs if the source file is on a network drive: the location of the destination folder does not cause any problem.
  • Pepin
    • May 2008
    Re: CoreConverter.exe problem with LAME + network drive
    I posted too fast. The problem is not related to a network drive but to a malformed tag created by Tag&Rename.
    I will try to investigate further before reporting more details.
    Sorry.
    P.
      If you can send a file with an example tag:
