popup info problem
  • Aelux
    • Mar 2008
    popup info problem
    Ok, i've re-installed dbpoweramp 12.4 several times and for some reason, the popup info works for all files EXCEPT mp3... This makes no sense at all. I'm running vista too. I don't know if it has to do with file associations or not.
    Help is appreciated, thanks.
    ::edit::
    Also too, the explorer columns are enabled in the program, but they arn't shown when I try to look a them in explorer
    Re: popup info problem
    Columns will not work in Vista.
    What is shown for the popup info for mp3 files?
    • Aelux
      • Mar 2008
      The regular pop info...it's like it doesn't even access the popupinfo.exe
        If you hold your mouse over another audio file type, does the pop-up say "dBpoweramp" at the bottom?
        • Aelux
          • Mar 2008
          yes it does
            What other items show up in the right-click menu for mp3s that does not look like the normal windows "open, copy, paste" etc. ?
            • Aelux
              • Mar 2008
              The dbpoweramp convert to and edit id3tag
