right click errors. file assciation/ context issue
    Help!!
    I have just installed dbpoweramp and now whenever I right click on ANY audio format file I get an access violation error.
    It launches several other applications and then crashes Explorer.
    I can not even use the icons in Explorer to copy or modify ANY audio format file.
    I know someone else that had this problem but their cure was to reformat the drive and start over.
    I really don't want to do that :-}
    I am using WIN NT 4.0 sp5
    thanks
    Try deleting the folder C:\Program Files\Illustrate\dBpowerAMP
    (if you have my audio player backup your music collection first)
    Then try to just install dMC.
