LAME Encoding Quality help
  • mynameismatt
    • Dec 2007
    I was wanting to know if dBPoweramp's LAME quality setting: Slow (High Quality) is the same as 0, Highest Quality (Very slow) found in other rippers with LAME? Or is dB's High Quality = to 2 High Quality found on other LAME rippers?
    I know I should, but I don't understand the command lines stuff. :(
    Thanks!
    The below is a quote from Spoon in the FAQs.
    This one gets asked alot, generally speaking mp3 quility comes from bitrate (or quality setting), but in addition lame has different internal encoding algorithms (as set by dBpoweramps Encoding setting in mp3 (Lame)).
    These switches are set on lame command line with 'f' and 'h' and are documented as:
    -h higher quality, but a little slower. Recommended.
    -f fast mode (lower quality)
    For R13 dBpoweramp matches lames mode with:
    Normal = Lame default
    Slow = Lame High Quality
    Fast = Lame Fast Mode
    Re: LAME Encoding Quality help
    It is the same as lame.exe (for R13).
