Problem encoding to AAC
  • weadley2004
    • Dec 2007
    I'm trying to rip some CDs for my wife's iPod. I'd like to end up with .aac format files (the AAC codec). The issue is that when I finish a rip I have 0k .aac files in my directory, along with a collection of .tmp files. It seems like the toaac.bat file is not getting executed to finish the process...?
    I've downloaded and installed both the m4A Nero (AAC) and the AAC codecs from dbPoweramp. I've also done the additional configuration steps to copy some of the Nero files into the encoder directories for the above. I hit the same issue when ripping directly from CD or using the batch converter from FLAC files.
    What am I doing wrong?
  • Wayne
    • Aug 2002
    • 1254
    Re: Problem encoding to AAC
    Can you turn on the Music converter debug option which can be found at the bottom of the Music converter tab on dBpowerAMP Configuration.
    After you do so attempt to convert again and post the log here.
    • weadley2004
      • Dec 2007
      Here is the log:
      Splitting Command Line:Done
      ->-> [dBCoreConverter::ReaddBCommandFile]
      <-<- [dBCoreConverter::ReaddBCommandFile]
      ->-> [cldBCodecHandler::FindDecoder]
      Checking Decoder 'C:\Program Files\Illustrate\dBpoweramp\decoder\FLAC.dll' for extension '.flac'
      Decodes [clDecoder::Get]
      <<< Match, using decoder
      Using Registry Cached Decoder: C:\Program Files\Illustrate\dBpoweramp\decoder\FLAC.dll
      ->-> [clDecoder::Close]
      <-<- [clDecoder::Close]
      <-<- [cldBCodecHandler::FindDecoder]
      BatchID [clDecoder::Set]
      ->-> [cldBCodecHandler::LoadEncoder]
      Loading Encoder 'C:\Program Files\Illustrate\dBpoweramp\encoder\AAC (Advanced Audio Compression).DLL'
      <-<- [cldBCodecHandler::LoadEncoder]
      BatchID [clEncoder::Set]
      ->-> [dBCoreConverter::StripCoreConverterCmds]
      <-<- [dBCoreConverter::StripCoreConverterCmds]
      SendRawUnCompressed [clEncoder::Get]
      Communicate [clDecoder::Get]
      Communicate [clEncoder::Get]
      NeedHQAudio [clEncoder::Get]
      Decode As [clDecoder::Set]
      ->-> [clDecoder::Open]
      Opening file 'D:\Audio\David Bowie\Diamond Dogs\Diamond Dogs.01.Future Legend.David Bowie.flac' for read access: Opened
      Init FLAC:
      Reading Meta Data:
      contained 25 tags:
      replaygain_album_gain: -5.35 dB
      replaygain_album_peak: 1
      AccurateRipResult: AccurateRip: Accurate (confidence 9) [7E5DB0F7]
      AccurateRipDiscID: 013-0015d4b5-00dc5fb2-aa0ae20d-1
      Album Artist: David Bowie
      Composer: David Bowie
      Disc: 1/1
      Label: RCA
      Style: Proto-Punk
      Pop/Rock
      Glam Rock
      Prog-Rock/Art Rock
      Hard Rock
      Rating: 4
      Source: CD (Lossless)
      Encoded By: dBpoweramp Release 12.3
      Encoder: FLAC 1.2.0
      Encoder Settings: -compression-level-5 -verify
      Length: 60533
      CDDB Disc ID: AA0AE20D
      replaygain_track_gain: -2.15 dB
      replaygain_track_peak: 0.831055
      Publisher: EMI (EMI)
      title: Future Legend
      Track: 1
      Album: Diamond Dogs
      Artist: David Bowie
      Genre: Rock
      Year: 1974
      Contains picture block, size (bytes): 18232 type: 3
      ->-> [clDecoder::ReadIDTags]
      <-<- [clDecoder::ReadIDTags]
      ->-> [clDecoder::FillAudioProps]
      Encoder: FLAC reference libFLAC 1.2.0 20070715
      Sample Count: 2,669,520
      ID Tag: Vorbis Comments
      Contains: Album Art, CRC, ReplayGain, ID Tag [Vorbis Comments]
      <-<- [clDecoder::FillAudioProps]
      ->-> [clDecoder::FillAudioInfo]
      Uncompressed WFX (sent to db): Format Tag: 1 Channels: 2 Bits per Sample: 16 Samples Per Second: 44100 Bytes Per Second: 176400 Block Align: 4 CB Size: 0
      Audio Length: 60533 mili-seconds 6365062 bytes 1411 kbps
      <-<- [clDecoder::FillAudioInfo]
      Creating Decode Buffers: Created
      <-<- [clDecoder::Open]
      Setting Priority: high [dBCoreConverter::SetConversionPriority]
      Priority [clEncoder::Set]
      ->-> [clEncoder::BeginConversion]
      Converting to 'D:\Audio\David Bowie\Diamond Dogs\Diamond Dogs.01.Future Legend.David Bowie.aac' encoder settings ' -cli_encoder="C:\Program Files\Illustrate\dBpoweramp\encoder\AAC (Advanced Audio Compression)\neroAacEnc.exe" -cli_cmd="-q .65 -ignorelength -hinttrack -if - -of {qt}[outfile].tmp{qt}" -selection="0,7,0"'
      Using Encoder 'C:\Program Files\Illustrate\dBpoweramp\encoder\AAC (Advanced Audio Compression)\neroAacEnc.exe'
      Command Line '-q .65 -ignorelength -hinttrack -if - -of "D:\Audio\David Bowie\Diamond Dogs\Diamond Dogs.01.Future Legend.David Bowie.aac.tmp"'
      Input Wave Format:Format Tag: 1 Channels: 2 Bits per Sample: 16 Samples Per Second: 44100 Bytes Per Second: 176400 Block Align: 4 CB Size: 0
      Output Wave Format:Format Tag: 1 Channels: 2 Bits per Sample: 16 Samples Per Second: 44100 Bytes Per Second: 176400 Block Align: 4 CB Size: 0
      Passing Wave Header: Yes
      Using StdInput Pipe: Yes
      dBpoweramp Writing Tags: Yes
      <-<- [clEncoder::BeginConversion]
      Encoding To: AAC (Advanced Audio Compression)
      Encoder Cmd Line: -cli_encoder="C:\Program Files\Illustrate\dBpoweramp\encoder\AAC (Advanced Audio Compression)\neroAacEnc.exe" -cli_cmd="-q .65 -ignorelength -hinttrack -if - -of {qt}[outfile].tmp{qt}" -selection="0,7,0"
      ->-> [dBCoreConverter::CloseDecoder]
      ->-> [clEncoder::EndConversion]
      Running program after conversion 'C:\Program Files\Illustrate\dBpoweramp\encoder\AAC (Advanced Audio Compression)\toaac.bat' Command Line: D:\Audio\David Bowie\Diamond Dogs\Diamond Dogs.01.Future Legend.David Bowie.aac
      Program completed
      <-<- [clEncoder::EndConversion]
      ->-> [dBCoreConverter::IDTagWriter]
      Checking Decoder 'C:\Program Files\Illustrate\dBpoweramp\decoder\aac.dll' for extension '.aac'
      Using Registry Cached Decoder: C:\Program Files\Illustrate\dBpoweramp\decoder\aac.dll
      IDTags [clDecoder::Set]
      <-<- [dBCoreConverter::IDTagWriter]
      Conversion completed in 9.5 seconds x6.4 realtime encoding
      For what it's worth, the command-line above has an option included that I don't see in the NeroAacEnc -help file...?:
      C:\Program Files\Illustrate\dBpoweramp\encoder\AAC (Advanced Audio Compression)>
      neroAacEnc -help
      * Nero Digital Audio Reference MPEG-4 & 3GPP Audio Encoder *
      * Copyright 2007 Nero AG *
      * All Rights Reserved Worldwide *
      * Package build date: Aug 6 2007 *
      * See -help for a complete list of available parameters. *
      Usage:
      neroAacEnc [options] -if <input-file> -of <output-file>
      Where:
      <input-file> : Path to source file to encode.
      The file must be in Microsoft WAV format and contain PCM data.
      Specify - to encode from stdin.
      Note that multiple input files can be specified, they will be
      encoded together into a single output file with chapter marks
      indicating source file divisions.
      <output-file> : Path to output file to encode to, in MP4 format.
      ==== Available options: ====
      Quality/bitrate control:
      -q <number> : Enables "target quality" mode.
      <number> is a floating-point number in 0...1 range.
      -br <number> : Specifies "target bitrate" mode.
      <number> is target bitrate in bits per second.
      -cbr <number> : Specifies "target bitrate (streaming)" mode.
      When neither of above quality/bitrate options is used,
      the encoder defaults to equivalent of -q 0.5
      Multipass encoding:
      -2pass : Enables two-pass encoding mode.
      Note that two-pass more requires a physical file as input,
      rather than stdin.
      -2passperiod : Overrides two-pass encoding bitrate averaging period,
      <number> : in milliseconds.
      : Specify zero to use least restrictive value possible (default).
      Advanced features / troubleshooting:
      -lc : Forces use of LC AAC profile (HE features disabled)
      -he : Forces use of HE AAC profile (HEv2 features disabled)
      -hev2 : Forces use of HEv2 AAC profile
      Note that the above switches (-lc, -he, -hev2) should not be
      used; optimal AAC profile is automatically determined from
      quality/bitrate settings when no override is specified.
      -ignorelength : Ignores length signaled by WAV headers of input file.
      Useful for certain frontends using stdin.
        • 46167
        Make sure you have the lastest m4a codec from codec central, we dropped the hinttrack option.
        • weadley2004
          • Dec 2007
          I am up-to-date on my m4a install (Release 7), but it looks like there may be an issue with the encoder.txt file laid down with the aac codec?
          When I run the "aac Release 1 474 KB" install it puts an encoder.txt file in my \encoder\AAC (Advanced Audio Compression) subdirectory that includes the -hinttrack option. Conversion to AAC fails in this case.
          If I copy the encoder.txt file derived from the "m4a Release 1 1047 KB" install from the "m4a Nero (AAC)" directory the conversion appears to work?
          Should the "aac Release 1" codec be updated or was I wrong to install it?
          Thanks for the quick responses!
          Mike
          • rlvlcv
            • Nov 2008
            Has there been a fix for this? I am using 13.1 with latest codecs. My logs also show that the toaac.bat batch file completed. Thanks.
              • 46167
              The .m4a codec would be a better choice for the original poster. Are you sure that .aac is the right codec for you, not the m4a?
              • rlvlcv
                • Nov 2008
                I could really use either codec, but for a product I paid for, I'd really like to be able to convert to any format the product says it will. Not to be a *blooper**blooper**blooper**blooper**blooper* or anything.
                • rlvlcv
                  • Nov 2008
                  Bump
                    • 46167
                    I have marked it as a possible bug ot look at.
                    • weadley2004
                      • Dec 2007
                      I switched to using m4a instead of aac and things are now working fine for me. I created custom encoder entries to encode Apple Lossless .m4a and Apple Lossy .m4a.
