CoreConverter.exe has encountered a problem and needs to close
  • Dalecent
    • Dec 2007
    I purchased dBpoweramp earlier today and have tried several times to convert m4a to mp3, I continually receive a windows message "CoreConverter.exe has encountered a problem and needs to close".
    This happens for both bulk and individual conversions.
    The file is only approx 30% converted.
    Have tried at 128 up to 192 with constant bitrate
    Can anyone help?
    Thx
    Re: CoreConverter.exe has encountered a problem and needs to close
    Where did the m4a file come from? can any other player play it?
      Are you forcing an encoding profile such as HE?
      • Dalecent
        • Dec 2007
        It happens with many tracks.
        All were playing in itunes.
        • Dalecent
          • Dec 2007
          No, encoding is set to normal
            What CPU do you have? Are you using the normal encoder or the SSE2 encoder?
            • Dalecent
              • Dec 2007
              CPU is Intel Pentium M 1.86Ghz
              Using normal lame encoder as came with dbpoweramp download
                If youhave one file which crashes consistently please send:
                • Kastchei
                  • Oct 2008
                  Has there been any followup to this problem?
                    It is likely that file was send (an apple lossless) and changes to the decoder were made (it was 1 year ago...)
                    • harrypt
                      • Jan 2010
                      • 10
                      I am now having this problem. I have had dbpower amp for some time but the problem is new.
                      CoreConverter.exe has encountered a problem and needs to close. We are sorry for the inconvenience.
                      Error signature:
                      AppName: coreconverter.exe AppVer: 13.3.0.2 ModName: resample.dll
                      ModVer: 3.0.0.1 Offset: 00009e1d
                      This happens at the end of every song and it won't continue ripping until I click thru the error screens.
                      Was there ever a fix for this?
                        Try installing the latest DSP effects, because Resample.dll which is crashing, you have an older version.
                        • harrypt
                          • Jan 2010
                          • 10
                          Just uninstalled old, downloaded new and installed. Problem has not changed. Crashes after each file encoded.
                            You are ripping a CD and changing the frequency to what value? (you have added the Resample DSP effect to CD Ripper).
                            • harrypt
                              • Jan 2010
                              • 10
                              Yes, I have. I'm using multi encoder and I have it set to rip two files:
                              1. AIF with the HDCD encoder enabled, no other change.
                              2. Apple Lossless with the Resample set to 44.1 and bit depth to 16.
