Right Click Doesn't Work
  • blt
    • Oct 2007
    Just upgraded to r12.3 Reference and registered, and now my right-click capabilities are GONE. I followed the FAQ procedure plus a few more, but no joy. Any suggestions?
    Re: Right Click Doesn't Work
    Version of Windows? Running as Administrator?
    • blt
      • Oct 2007
      WinXP Pro SP2, Admin privileges. The right-click worked until I upgraded from R11.n
        You tried disabling the right-click, rebooting, re-enabling, then rebooting again, correct? What other programs show up when you right-click? You might want to try using "ShellEx" to selectively disable the right-click menus to see if the dMC menu comes back.
        • keithperdue
          • Oct 2007
          I have the same problem, I installed trial 12.3, everything was fine then I purchased and installed licensed version, now I have no right click option to convert and dbPowerAmp Configuration has gone AWOL.
            Uninstall dBpoweramp, reboot windows, install registered version.
            • keithperdue
              • Oct 2007
              Thanks, have done that and all is back as it should be :komisch9:
