Startup problem with CD Ripper in 12.3 Reference
  • Magicd0n
    • May 2007
    I just upgraded to R12.3 Reference and I am now having a problem with startup on the CD ripper.
    When I right click on my DVD-rom drive and choose "Rip with dBPowerAmp" from the context menu the program starts up behind all other running windows and doesn't appear in the task bar. If I go to Task Manager it shows that it is running but the 'switch to' button doesn't make it appear on the task bar.
    If I minimize all open windows, then dBPower Amp CD Ripper appears on screen and in the taskbar and seems to work normally.
    Thanks for the help.
    -Don
    Re: Startup problem with CD Ripper in 12.3 Reference
    Which windows version? on Vista it appears in the front when I try it.
      Nevermind, thanks petriburg
      Can you Alt-Tab to the program?
      • petriburg
        • 172
        Lt.Data - he's using 12.3 Reference, as he quoted in his first post.
