Summary not showing up after secure rip in Reference 12.3
  • Magnus_CA
    • Sep 2007
    • 47
    Hello,
    Due to the way the Secure Options screen is written it appears as though a summary screen is supposed to appear after the job is complete. I'm expecting a "Secure Extraction Log" or some kind of summary to appear but it's not. I have the "Add to Information Log" box checked under the Secure Extraction Log section of the Secure option screen.
    Thanks in advance for the help!
    Re: Summary not showing up after secure rip in Reference 12.3
    The results show in the main window, not a separate pop-up.
    • Magnus_CA
      • Sep 2007
      • 47
      Yes, but after the disc is done ripping I just get a prompt to insert a cd into my drive. The results go away once the disc is done ripping.
        You have dMC set to eject the CD after it is done ripping?
        • Magnus_CA
          • Sep 2007
          • 47
          Yes. Provides a nice convenience factor. I'll give it up if I can get a rip summary.
            You can have dMC write a log file, but I'm not sure how you would get a rip summary if the disc as just ejected
              Click the down arrow next to Options and check the option to view info log after ripping.
              • Magnus_CA
                • Sep 2007
                • 47
                Can you post a screenshot of the info log? I don't believe mine is showing up.
                  These options cecked:
                  Options Drop Menu >> After Ripping >> Display Information Log
                  Secure Rip checked
                  Secure Settings >> Add to Information Log
