flac conversion and ID tags
  • Crossie
    • Sep 2007
    I have a problem losing ID tags when I convert flac files to Apple lossless.
    My source files were ripped using CDex as flac format (approx 50% compression) for streaming to Squeezebox and I am trying to batch convert them for use on an Ipod Nano to AAC.
    I have tried using the Nero codec as this allows me to set the output files to 128-Kbps AAC which the apple lossless codec does not seem to allow. When I use this codec I loose all the ID tags and then Itunes imports each track seperately rather than as part of an album.
    If I convert from flac using the apple lossless codec I get huge files but the ID tags remain intact. If I then use the Nero codec on these files I get smaller files and the ID tags still remain intact!
    If anyone has any ideas why the Nero codec strips the ID tags from the original flac files I would be very grateful as I don't really want to have to do a two stage process.
    Have I missed some options somewhere...
    Thanks in advance.
    Dave
    Re: flac conversion and ID tags
    Hold the mouse over both files (source and converted) dBpoweramp will show which files contain tags.
      Upgrade to the latest m4a beta codec in the beta section of this forum.
      • Crossie
        • Sep 2007
        Sorted.
        Fantastic.
        Thank you very much.
        Dave
