DSP Effects won't work together!
  • Thymaster
    • Aug 2007
    • 8
    I use the registered version of dbPowerAmp 12.3 incl. the DSP-Pack.
    When I try to combine the "Maximum Length" and the "Normalize" DSP effect when converting a mp3 file I get the following message:
    Code:
    Error converting to mp3 (Lame), 'M:\Musik\@Various\Schlager\Marlene Dietrich - Sag mir wo die Blumen sind.mp3' to 'C:\Marlene Dietrich - Sag mir wo die Blumen sind.mp3'
       Error: Writing Temporary Rendered DSP file, disk full?.  [dBCoreConverter::HandleNonLiveDSPs]
    There seem to be more combinations where this error occurs, it seems that the "Maximum Length" effect is the root cause.
    Please fix.
    Thanks a lot in advance.
    Regards
    ThyMaster
    Re: DSP Effects won't work together!
    Type start >> run and %temp% then press enter. Does this temp drive have enough space?
    • tcbb
      • Mar 2007
      • 18
      I have the same exact problem,,, per thris thread
      maximum length seems to sometimes cause a conflict with certain combinations of DSP's.
      • Thymaster
        • Aug 2007
        • 8
        It does have enough space. I'm sure it's a bug within the DSP effects.
        Just try it yourself!
        Regards
        ThyMaster
        • tcbb
          • Mar 2007
          • 18
          just curious,,,, is this being investigated?
            This issue will be looked at for R12.4, work will start on it in 2-3 weeks.
              Now fixed in DSP Effects R2.
