FLAC to ALAC problem (skipping tracks)
  • John Doh
    • Aug 2007
    I'm converting my FLAC music files to Apple Lossless (ALAC) so I can put the files on my iPOD. The files convert fine. The sound quality is fine. They transfer to the iPOD fine. The problem comes when I am playing the music on my iPOD. If I play an album, it will skip everyother song. (ex: play track 1, then skip to track 3, then to 5, etc.)
    The albums play fine in iTunes (no track skipping). It's just on my ipod. Any help?
    Re: FLAC to ALAC problem (skipping tracks)
    This is a known problem. I think one fix is to run the "m4a optimize" utility codec on the files after converting to ALAC, which is in the "m4a utilities" codec on the m4a codec page.
    • John Doh
      • Aug 2007
      Thank you sir. I will try that and report back.
      • John Doh
        • Aug 2007
        Seems to have worked. :lustig12:
        Thanks for the help.
