Using CUE to split audio file
  • mirage93i
    • Jul 2007
    Hello,
    Is it possible to use CUE file during conversion to split big audio file (APE/FLAC...) to corresponding small parts? Actually I have not found any
    reference to CUE on this forum.
    Best regards,
    Alexander
    • 45570
    Re: Using CUE to split audio file
    Not currently, it is expected in R13.
    • mirage93i
      • Jul 2007
      Could I ask you about due date of R13? As I need to know how long time I will need to use additional tools.
      Thank you in advance,
      Alexander
      • Tigerman
        • Mar 2005
        • 157
        I use cuesplitter to split ape & flac files:
        Looking for a quick and easy way to manage your files or organize audio tracks? Medieval Software has the tools you need! Explore our unique approach to digital organization.
        "Happiness is nothing more than good health and a bad memory."
        Albert Schweitzer (1875 - 1965)
          • 45570
          R13 release is very difficult to say when, there is quite a feature set with it.
          • IamNemo
            • Sep 2008
            • 39
            With the converter R13.2 is it now possible to split Flac and APE files according to CUE file?
            If not: Any other tool to suggest? Foobar2000, Medieval (is it good?), etc?
            Thanks!
              • 45570
              Not implemented in r13 (although you can create cuesheets with CD Ripper)
              • Tigerman
                • Mar 2005
                • 157
                In the almost 2 years since my last reply in this thread, I found in cuetools a much better splitter.
                It can do much more than splitting, but you have to read and test a bit before you can use all the functionality.
                • IamNemo
                  • Sep 2008
                  • 39
                  Thanks for the tip Tigerman! I will try it right away. Cheers, IamNemo
                  • Tenerife
                    • Sep 2010
                    • 13
                    Does v.14 of dBp support splitting a FLAC based on a cuetools-generated .cue? If so, how?
                    Thank you.
                      • 45570
                      It does not.
                      • imeric
                        • Mar 2011
                        Still a no with r15? This would be a really nice feautre to have.
                        thx!
                          • 45570
                          Sorry no.
                          • Michael Sargent
                            • Dec 2009
                            • 135
                            Thank you.
                            foobar2000 does and it's free.
                            Mike
                            • WhoSaidThat
                              • Jul 2018
                              Sorry no.
                              What about R16?
