Problems, CD burner especially
  • choenyi
    • Jul 2007
    I had a request for AAC files, so I upgraded to be able to use the codec.
    Whoops, my registration was then lost. $30 ...
    CD writer then not working. Another $30 ...
    Now I have purchased both twice, *but*
    I cannot burn CDs.
    I read somewhere here that it's being worked on?
    How soon can I right-click a file and choose "Convert to" ... "Audio CD" ?
    I hope soon :blush:
    Re: Problems, CD burner especially
    Install dMC r11.5 and the CD Writer to the same directory as stated here: http://www.dbpoweramp.com/legacy-compatibility.htm. If you want dMC r12, install that to a totally separate directory than the two above programs. And yes, a dMC r12 compatible version of dCW is being worked on.
    Also, if your purchase was within 2 years and you cannot find your registration information, you can have your registration info looked up manually, as stated here: http://www.dbpoweramp.com/registration/
