R12.2 reference dynamic naming problem
  • TarkusShakti
    • Jul 2005
    • 102
    I'm having a problem with dynamic naming in Ref 12.2. I'm trying to code this:
    If there is no artist tag, then name the file "original path\original filename"; else name the file: artist\artist - year_album\track title.
    I've tried:
    [IFVALUE][artist],[artist]\[artist] - [year]_[album]\[track] [title],[origpath]\[origfilename][]
    which names all files in the "strnovalue" fashion
    and
    [IFVALUE]artist,[artist]\[artist] - [year]_[album]\[track] [title],[origpath]\[origfilename][]
    which names all files in the "strifvalue" fashion
    What is the tag argument supposed to be?
    thanks
    TS
    ASUS P8P67 PRO (Rev3.0)(BIOS 1502) ~ Core i5 2500K 3.3G ~ 16 gb G.Skill Ripjaws X DDR3 1600 - Sapphire HD5700 w/1Gb ~ 1 - Corsair Force Series 60 Gb SSD ~ 2 - Samsung HD204UI 2 tb ~ 2 - Samsung HD753LJ 750 gb ~ 1 - Pioneer DVR-212D ~ SeaSonic S12II 520W ~ Lian-Li PC70 ~ I boot Win7 SP1 on this desktop.
    or
    ASUS G71Gx (BIOS 1704) ~ Core Duo P8700 ~ 6 gb DDR2 ~ Geforce GTX 260M w/ 1 gb DDR3 ~ I boot Win7 SP1 on this laptop.
    • 46228
    Re: R12.2 reference dynamic naming problem
    Works for me (tried 2 monkeys audio files, one with and one without artist, rght click >> convert to, added your line and did the List / Rename and it shows both correct paths).
      • 46228
      Was the correct one. Which files are you converting from? it is as though they all have artist tags.
      • TarkusShakti
        • Jul 2005
        • 102
        I'm converting from flac -> mp3 (lame). Here are the results of converting two Bruce Hornsby songs (with tags) and two genesis songs (without tags):
        G:\02\02 - _\ The Musical Box
        G:\01\01 - _\ For Absent Friends
        G:\Bruce Hornsby\Bruce Hornsby - 2004_Greatest Radio Hits
        This is using this:
        Must be a bug then...I'm running WinXP SP2, configuration is in my sig...
        Can it be said (about dynamic naming) that "artist" is a tag and "[artist]" is a tag value?
        TS
        or
          • 46228
          What are the original filenames for all 4 files?
          • TarkusShakti
            • Jul 2005
            • 102
            \Bruce Hornsby - 2004_Greatest Radio Hits\The Way It Is.flac
            \Bruce Hornsby - 2004_Greatest Radio Hits\Mandolin Rain.flac
            \Genesis - 1971_Nursery Cryme\For Absent Friends.flac
            \Genesis - 1971_Nursery Cryme\The Musical Box.flac
            also, in my last post I neglected to provide the finished filenames for the mp3s - they are:
            \01\01 - _\ For Absent Friends.mp3
            \02\02 - _\ The Musical Box.mp3
            \Bruce Hornsby\Bruce Hornsby - 2004_Greatest Radio Hits\01 The Way It Is.mp3
            \Bruce Hornsby\Bruce Hornsby - 2004_Greatest Radio Hits\02 Mandolin Rain.mp3
            TS
            or
            • TarkusShakti
              • Jul 2005
              • 102
              TS
              Can I get an answer here too?
              or
                • 46228
                Yes
                Open note pad and drop one of the files with supposidly no artist onto notepad, make sure word wrap is switched on and loo for the tag block (near the start), can you see ARTIST= there?
                • TarkusShakti
                  • Jul 2005
                  • 102
                  Nope not there... I guess mp3tag, tagscanner and your own "right-click in explorer tag editor" are correct and there are no tags in that file!
                  Here's one more for you: If the conversion window is minimized when it finishes, all the buttons on it disappear when you restore the window... Been like this since R12.0.
                  PS those red lines under words in the Edit Post window means those words might be mis-spelled.
                  TS
                  or
                  • TarkusShakti
                    • Jul 2005
                    • 102
                    I created some new flacs without tags and stripped tags from some existing flacs and they still fail to produce the expected results with Dynamic Naming. Maybe it's time to look at the code vs. my flac files...
                    TS
                    or
                      • 46228
                      will look asap.
                        • 46228
                        Here is what I did:
                        Create 2 flacs from the same file, used dbpoweramp to remove the artist from one, then converted flac >> flac with dynamic naming:
                        bob\[IFVALUE]artist,[artist]\[artist] - [year]_[album]\[track] [title],[origpath]\[origfilename][]
                        They both went into different folders correctly named.
                        • TarkusShakti
                          • Jul 2005
                          • 102
                          Here is what I did:
                          ...and what OS did you do this under? I'm using WinXP SP2.
                          TS
                          or
                          • TarkusShakti
                            • Jul 2005
                            • 102
                            I think I have found out why we are experiencing different results.
                            Dynamic Naming works if the tag is empty, but doesn't work if there is no tag at all. You should try a file which has never had a tag or a program (TagScanner) which removes the tag entirely.
                            TS
                            or
                              • 46228
                              I might be wrong, but if a file has no tags, dbpoweramp creates an artist and title tag from the filename automatically.
