Error "Error decoding decoding audio, audio corrupt? [clDecoder::DecodeBlock]"
  • cs8alm
    • Jun 2007
    Hi I have 3000 WMA lossless audio (9.2) files that I am trying to convert to flac 1.1.4. I get the following error for each file:
    Error converting to FLAC, 'C:\Users\Ade\Music\Windows Media\Anastacia\Anastacia\07 Welcome To My Truth.wma' to 'C:\Users\Ade\Music\FLAC\07 Welcome To My Truth.flac'
    I am using dbPowerAmp Reference 12.1 with the FLAC codec Release 9 and WMA code release 3 for Vista (as the software is installed on vista).
    Any idea as to what is going wrong?
    Thaks
    Ade
  • cs8alm
    • Jun 2007
    Re: Error "Error decoding decoding audio, audio corrupt? [clDecoder::DecodeBlock]"
    This is what the log produces...
    Splitting Command Line:Done
    ->-> [dBCoreConverter::ReaddBCommandFile]
    <-<- [dBCoreConverter::ReaddBCommandFile]
    Allying to Processor 1
    ->-> [cldBCodecHandler::FindDecoder]
    Checking Decoder 'C:\Program Files\Illustrate\dBpoweramp\decoder\Windows Media Audio.dll' for extension '.wma'
    Decodes [clDecoder::Get]
    <<< Match, using decoder
    Using Registry Cached Decoder: C:\Program Files\Illustrate\dBpoweramp\decoder\Windows Media Audio.dll
    ->-> [clDecoder::Close]
    <-<- [clDecoder::Close]
    <-<- [cldBCodecHandler::FindDecoder]
    BatchID [clDecoder::Set]
    ->-> [cldBCodecHandler::LoadEncoder]
    Loading Encoder 'C:\Program Files\Illustrate\dBpoweramp\encoder\FLAC.DLL'
    <-<- [cldBCodecHandler::LoadEncoder]
    BatchID [clEncoder::Set]
    ->-> [dBCoreConverter::StripCoreConverterCmds]
    <-<- [dBCoreConverter::StripCoreConverterCmds]
    SendRawUnCompressed [clEncoder::Get]
    Communicate [clDecoder::Get]
    Communicate [clEncoder::Get]
    NeedHQAudio [clEncoder::Get]
    ->-> [clDecoder::Open]
    Opening file 'C:\Users\Ade\Music\Windows Media\Anastacia\Anastacia\07 Welcome To My Truth.wma' for read access: Opened
    ->-> [clDecoder::ReadIDTags]
    Contains 12 tags:
    Title: Welcome To My Truth
    Artist: Anastacia
    Year: 2004
    Label: Sony
    Genre: Pop
    Album: Anastacia
    Album Artist: Anastacia
    _cdtoc: DATA Length: 148 C.+.9.6.+.4.C.0.F.+.
    WM/Provider: AMG
    WM/ProviderStyle: Rock
    Track: 7
    Composer: Anastacia
    J. Shanks
    K. Dioguardi
    <-<- [clDecoder::ReadIDTags]
    Parsing File
    Created
    ->-> [clDecoder::FillAudioProps]
    Encoder: Windows Media Audio 9.2 Lossless
    Encoder Settings: VBR Quality 100, 44 kHz, 2 channel 16 bit 1-pass VBR
    Sample Count: 10,719,783
    ID Tag: WMA ID Tag
    Contains: CD TOC, Normalization Values, ID Tag [WMA ID Tag]
    <-<- [clDecoder::FillAudioProps]
    ->-> [clDecoder::FillAudioInfo]
    Uncompressed WFX (sent to db): Format Tag: 1 Channels: 2 Bits per Sample: 16 Samples Per Second: 44100 Bytes Per Second: 176400 Block Align: 4 CB Size: 0
    Audio Length: 243078 mili-seconds 31189318 bytes 1411 kbps
    <-<- [clDecoder::FillAudioInfo]
    Creating Decode Buffer: Created
    <-<- [clDecoder::Open]
    ->-> [clEncoder::BeginConversion]
    Converting to 'C:\Users\Ade\Music\FLAC\07 Welcome To My Truth.flac.tmp.flac' encoder settings ' -compression-level-5'
    FLAC Compression Level: 5
    <-<- [clEncoder::BeginConversion]
    Encoding To: FLAC
    Encoder Cmd Line: -compression-level-5
    *** Error: Error decoding decoding audio, audio corrupt? [clDecoder::DecodeBlock]
    ->-> [dBCoreConverter::CloseDecoder]
    ->-> [clEncoder::EndConversion]
    <-<- [clEncoder::EndConversion]
      Re: Error &quot;Error decoding decoding audio, audio corrupt? [clDecoder::DecodeBlock]&quot;
      If you choose "Test Conversion" as you codec, do you still get this error? Can you convert your files to another format, such as WAV or mp3? The error seems to indicate that there is a problem decoding your WMA files. Can you play them in WMP? Are they encrypted?
        can windows media player play the files? are they copy protected?
