Problem converting .flac to .ogg (using AOTUV Lancer)
  • TrappyWappy
    • Jun 2006
    I'm using the latest codecs to convert some old .flac files, however, conversion stops after encoding a total of 10 seconds of audio on any and all .flac files.
    Weird and out of nowhere, I was able to convert them fine last week.
    Re: Problem converting .flac to .ogg (using AOTUV Lancer)
    Using a DSP effect?
      If you use the normal Ogg Vorbis codec, does it work fine?
      What version of dMC and of Windows are you using?
      • TrappyWappy
        • Jun 2006
        I'm using no DSPs. I'm running reference 12.1 and the normal vorbis encoder works fine. Also a side note: I can rip cds fine with no problems using the codec, but not with manual right click convert.
        woops: XP Home
          What is your CPU? And what is the error message you get?
