Problem with very long Titles
  • marcaurel
    • May 2007
    • 24
    If title has more than 133 chars
    no tags but the 2 AccurateRip-tags
    are written to the ripped file
    Re: Problem with very long Titles
    What version of dMC are you using? What file type is this? What type of tags are they, ID3 or APEv2 for mp3, for example?
    • marcaurel
      • May 2007
      • 24
      dBpoweramp Music Converter
      Release 12.1
      I encode to FLAC therefore I think it might be
      ID3. I use some extra tags on classical discs
      (and only for classical discs do I need such
      extraordinarily long titles, eg. Bach - St. Matthew Passion)
      eg. Conductor, Band, Label, Comment but
      everything works fine if title < 133.
      First I thought there could be a length-limit for tags
      but I can change the title without problems
      eg. by right-click "Edit ID-Tag".
        Does the entire title show up in the CD Ripper window? If you manually shorten the title to below 133 characters, do all of the tags get written.
        • marcaurel
          • May 2007
          • 24
          Yes, it shows up in the window.
          If the tag is shortened everything works ok
          (that's why I know that it's exactly 133 chars
          I did a lot of testing :smile2: )
            Can you post the exact track tile, album and artist please.
            • marcaurel
              • May 2007
              • 24
              OK.
              Here are the complete tags of one of the problematic tracks:
              ALBUM: Matthäus-Passion
              TITLE: 4a. Recitative (Evangelist): Da versammleten sich die Hohenpriester - 4b. Chorus: Ja nicht auf das Fest - 4c. Recitative (Evangelist): Da nun Jesus war zu Bethanien - 4d. Chorus: Wozu dienet dieser Unrat? - 4e. Recitative (Evangelist, Jesus): Da das Jesus merkete
              YEAR: 1989
              GENRE: Choral
              COMPOSER: Johann Sebastian Bach
              CONDUCTOR: John Eliot Gardiner
              COMMENT: Salbung in Bethanien
              BAND: The English Baroque Soloists
              LABEL: Deutsche Grammophon
              DISC: 1/3
              ARTIST: The Monteverdi Choir; Anthony Rolfe Johnson; Andreas Schmidt; Anne Sofie von Otter; Cornelius Hauptmann; Ann Monoyios; Barbara Bonney; Howard Crook; Michael Chance; Olaf Bär
              ACCURATERIPDISCID: 029-004186b9-0527a97c-a30f7b1d-4
              ACCURATERIPRESULT: AccurateRip: Inaccurate (confidence 1) Secure: Yes [9443F382]
              TRACK: 4/29
                Confirmed bug, next flac beta will fix.
