Easier way to add track numbers and titles?
  • GavSalkeld
    • Oct 2006
    • 55
    Hello all.
    I have around 82 WAVs I am converting to MP3s by right clicking and going to "Convert to". I wish to add ID3 tags to them all, and so I add a tag element option and type in the constants, i.e. year, artist, album, disc number.
    However, I cannot seem to add ID3 fields for the variables, i.e. track numbers and names. Is there a way to add in track numbers and titles using the "ID3 tag processing" DSP effect? Do I put # in the track number field, for example?
    Thank you.
    Re: Easier way to add track numbers and titles?
    There was a utility codec that would do this called "Tag from Filename". However, it has not been ported to r12 yet, so you will probably have to manually tag the files one a ta time, unfortunately. I don't know of a way to use variables to tag files.
    • GavSalkeld
      • Oct 2006
      • 55
      Thanks for that. Is there any idea if or when this will come over to v12?
        No idea, but I think it will come out for r12 at some point.
        • GavSalkeld
          • Oct 2006
          • 55
          Has this happened yet?
            Tag from Filename is available from Codec Central.
            • GavSalkeld
              • Oct 2006
              • 55
              Many thanks!
              Can this be used in conjuction with the ID3 tag writer, i.e. can I tag files from filename to fill in track numbers and titles and then use the writer to fill in genre, year, etc?
                Probably would have to do 2 runs: once for the tag from filename, once for the "ID Tag Update" utility codec.
                • GavSalkeld
                  • Oct 2006
                  • 55
                  You're right, I did that and it works fine.
                  Many thanks indeed.
