Tagging Problem with dbpa Batch Converter, FLAC > MP3
  • jamesbaud
    • Jul 2006
    • 34
    Windows Vista
    Running as Administrator
    dmc 12.1
    Converting to mp3 (LAME 3.97) using the built-in codec, -V 2, encoding: slow (high quality), force ISO compatibility, frequency and channels are set "as source"
    Converting from FLAC 1.1.4 files created with flac.exe (version 1.1.4), ripped from CDs "as source"
    I ripped the CDs to FLAC using the CD ripper.
    Then, I tagged the files with MP3TAG. The tags are in the FLAC format.
    Some of my CDs are duet compilations (i.e. Ray Charles / Nora Jones).
    The tag in the FLAC file correctly lists as "Ray Charles / Nora Jones".
    When I use the dbpa batch converter to transcode from FLAC > MP3, the "/" gets switched to "\".
    I tried it using both the built-in codec dll, and also creating a CLI with lame.exe. The "/" gets switched to "\" both times.
    This seems like a minor thing, but it's really annoying, as my music library in foobar gets all messed up.
    I have confirmed that this occurs only when using the dmc batch converter.
    I used Multi-frontend .983 to transcode the same FLAC file to MP3 (using flac.exe and lame.exe), and the "/" was intact.
    Can you please fix the bug in the 12.2 release? Thx.
    Re: Tagging Problem with dbpa Batch Converter, FLAC > MP3
    Which type of tag is being used in mp3?
    • jamesbaud
      • Jul 2006
      • 34
      Tag Creation: ID3v2
      ID3v2 version: v2.3
      ID3v2 text encoding: ANSI
