[PROBLEM] Converting WAV or MP3 to M4a Nero (AAC)
  • abhay
    • May 2007
    • 15
    #31
    Re: [PROBLEM] Converting WAV or MP3 to M4a Nero (AAC)
    Using that command the nero encoder converted the file successfully so it means that the exe is fine? I tried removing single quote from Aerosmith file but it didn't change anything. Same problem exists :|
      #32
      That means the exe is fine, yes.
      If you use dMC to encode the WAV file in the "conversion" folder, does it convert then?
      • abhay
        • May 2007
        • 15
        #33
        No it doesn't convert the wav file either. Is there any dbpoweramp cleaner sort of thing available using which I can remove all the settings/registry entries and start from scratch. I have k-lite codec pack installed. Can that cause some problems?
          #34
          No, I also have the K-Lite codec pack installed and I can convert just fine.
          To start from scratch, follow the instructions here: http://forum.dbpoweramp.com/showthread.php?t=6828
          • abhay
            • May 2007
            • 15
            #35
            Well I tried from scratch and it still didn't work. Looks like m4a doesn't like me :(
            I have decided to use lower bitrate ogg format. I have heard that is a good format as well.
            • WallyWalters
              • Oct 2002
              • 28
              #36
              Was the solution to this problem ever posted, here or anywhere else? I too have the problem of zero-byte m4a files output from dBpoweramp, though NeroAACEnc works fine from the command line.
              • WallyWalters
                • Oct 2002
                • 28
                #37
                Solved it. It happens if there are spaces in the file name and the Encoders.txt file doesn't have quotation marks around [infile].
