Conversion window not showing
  • GavSalkeld
    • Oct 2006
    • 55
    When I right click to convert a file, for some reason now the conversion window with the progress bar is minimizing to the taskbar and I cannot maximize it or restore. Its only recently started doing this, how do I stop it?
    Thank you.
    Re: Conversion window not showing
    Try r12.1, linked to below.
    • GavSalkeld
      • Oct 2006
      • 55
      Is it OK to install this over the registered beta I have?
        If you have a registered PowerPack version, yes. If you have a registered Reference version, use Registered link retrieval to update.
        • GavSalkeld
          • Oct 2006
          • 55
          I have a registered PowerPack. It worked fine, thank you ever so much. Whats a registered Reference version, whats the difference?
            Reference is a new version of dMC for "audio professionals and enthusiasts". http://www.dbpoweramp.com/dbpoweramp-reference.htm
            Differences are here: http://www.dbpoweramp.com/db-versions.htm
