Problem converting WAV to MPC using DMCr12
  • tomzwbyo
    • Feb 2007
    Installed DMCr12 with Musepack 1.16 and am trying to convert 44.1Khz 24bit WAV files into MPC, but get the following error :
    Error writing audiodata to StdIn Pipe [clEncoder::EncodeBlock]
    Could someone confirm that the problem is that the Muspack encoder does not support 24 bit? Would the musepack codec also have a problem with 96KHz sources files?
    Many thanks
    tomzwbyo
    Re: Problem converting WAV to MPC using DMCr12
    Try converting your WAV to a 44.1KHz 16-bit WAV and then see if it works. If it does, then MPC doesn't like 24-bit files, or at least your 24-bit file.
    • Lichtgestalt
      • Jul 2007
      I have the same problem. dMC and all codecs are installed in the same (default) location, all files I'm trying to convert are 44.1KHz 16-bit WAV just grabbed from CD-DA (with EAC). Almost every resulting file have size 0 bytes, and in log there are records "Error writing audiodata to StdIn Pipe [clEncoder::EncodeBlock]". But some(very rare)time conversion works. It happens in full random, so it isn't source files problem.
        Which windows version?
        • Lichtgestalt
          • Jul 2007
          WinXP SP2 with no further updates installed. I've forgot to specify versions of dmc and plugins I use - all latest (but not betas).
            Do you have any security set on the system, or security programs which are stopping the STDIO with mpc?
            • Lichtgestalt
              • Jul 2007
              Sorry, but I don't understand you :( Can you explain what do you mean?
                I know if you had a fresh Win XP system with latest updates then you would not have any problems, so there mush be a program or setting changed in Windows XP which is stopping this functionality.
                • Lichtgestalt
                  • Jul 2007
                  Hmm.. I'll try, but it's really strange - sometimes everything is OK, but very seldom. I mean that in batch of 20 files can be 1 or 2 converted normally, and can be none.
                  • Lichtgestalt
                    • Jul 2007
                    I've tried to convert pack of files on another machine, and problem didn't happened. Really strange..
