Problem ripping first CD
  • tmichel
    • Feb 2007
    I have a registered dbpowerAMP reference version r12. When I went to rip my first CD, I setup secure mode with C2 and so on. It ripped the first 12 of 13 songs to wav files just fine, but on the last song I get the following error message.
    Error ripping to Wave, 'Track 13' to 'C:\My Music\Lucinda Williams\Lucinda Williams - Car Wheels on a Gravel Road - 13 - Jackson.wav'
    Unable to read CD, check CD disc (frame LBA 233120 ripping 0 frames track end LBA 233120) [clRipperSecure::Rip]
    I don't see any surface marks on the disk at all. Of course the last track plays just fine. So I right-click on the track and say rerip insecure, and I get the same problem! The first 12 tracks showed accurate(9) for each.
    If I turn on any kind of encoding, it will fail to do the encode. I tried this on 2 different CD drives, but get the same error each time.
    I guess I can understand a flaw in the CD, but I don't understand why it doesn't continue and aborts the encoding process. My abort options claims to be set to "no abort".
    Manufacturer: SONY
    CD Drive: DVD RW DRU-710A
    Firmware: BY03
    Serial: Nov12 ,2004
    Maximum Speed: 7056 KB/sec (x40)
    Current Speed: 7056 KB/sec (x40)
    Spin-down After: 2 minutes
    Buffer Size: 2 MB
    Accurate Stream: Yes
    C2 Error Pointers: Yes
    Reads ISRC: Yes
    Reads UPC: Yes
    Tim
  • Wayne
    • Aug 2002
    • 1254
    Re: Problem ripping first CD
    Did you turn on the Read into Lead-in or Lead-out option?
    • tmichel
      • Feb 2007
      I did not, what does it do?
        It tells your CD burner to read into the "lead-in" and "lead-out" portions of the CD.
          This is a confirmed bug with certain drives, we are looking at a fix.
