dsp installation problems
  • csiron
    • Feb 2007
    • 33
    I've installed my registered Reference copy and everything seems to be working great except the installation of the DSP options. I understand that some are not available yet, but after choosing "Install DSP Effects Now..." and extracting the downloaded file to C:\Program Files\Illustrate\dBpowerAMP\DSPs, I can't find a way to select any of the DSPs.
    When I select "Load" and navigate to the folder where the effects are stored nothing is showing up as a "*.dspeffect" file.
    What am I missing?
    Re: dsp installation problems
    You restart the program, then Add DSP effect >> should list the new ones.
    • csiron
      • Feb 2007
      • 33
      Thanks, knowing what I was supposed to see helped me figure out what went wrong.
      It turns out the DSP folder was created within another DSP folder. My best guess is that the install went into a remnant folder from a previous install. Regardless, as soon as I moved everything over into the first folder in the nest, everything worked perfectly.
