Problem with Converting ??
  • mannaoz
    • Jan 2007
    • 9
    The program has never been a hitch until this happened today.
    I feel there may have been a malicious virus or something as the program disappeared from add remove programs.
    I reinstalled it with all the codecs I had and then tried to convert an audio track I had recorded using Nero Wave Edit. I use this method all the time with no problems.
    Now I am getting this message coming up.
    The CODEC required to compress 'H:\New (J)\X2o Folder\Audios\XoomaPartnersCall\Saturdays\MP3\Corp erate Update Call 20.01.07 Edit.mp3.TEMP.mp3' could not be opened.
    Error creating mp3 compressor, try different encoding frequency and bitrates.
    What is this and how do I get back to square one.
    I have again deleted the entire program and started again still have the same result. :(
    Please help
    Thanks in advance
    \Jeff
    Re: Problem with Converting ??
    Assuming your assumption is correct, try the total uninstall procedure described in the FAQ on Uninstall Issues and Fix here:
    http://forum.dbpoweramp.com/showthread.php?t=6828
    Bill
      What version of dMC are you using?
      • mannaoz
        • Jan 2007
        • 9
        Thanks Guys.
        I have deleted from the registry checked there were no extras hanging around and reinstalled.
        Seems to be working well.
        Now all I need to do is work out the best compression that has good quality sound playback. At the moment it sounds like a shortwave message. :yawn:
        The version I was using was 11.5 registered.
