Problem with WMA lossless to FLAC
  • jhenderson01075
    • Oct 2004
    • 12
    Hi -
    I recently purchased some WMA 9.1, 24-bit, 88.2 kHz lossless studio master tracks from LinnRecords.com that I wish to transcode to Flac 24-bit, 44.1 kHz. This is needed since my music players (Squeezebox 3) cant decode WMAs.
    I am using the latest dBPowerAmp Converter codecs downloaded from the Illustrate website yesterday. When I transcode to Flac, the resultant files are 16-bit, 44.1 kHz instead of 24-bit, 44.1 kHz. Is there a work-around?
    Thanks in advance,
    Jim
    Re: Problem with WMA lossless to FLAC
    Yes use R12 in beta.
    • jhenderson01075
      • Oct 2004
      • 12
      I just uninstalled my registered version of v11.5 dMC and codecs. Then, installed the version listed at the bottom of this post.
      After I right-clicking on a 24-bit, 88.2 kHz WMA to convert in the Win explorer, I select convert to Flac, level 5. But, it fails with the error message below:
      Error Message:
      Error converting to FLAC, 'M:\Lossless\Uber\Lazaridis, George-Emmanuel\Liszt Sonata and Etudes\7 - Grandes Etudes de Paganini Etude VI.wma' to 'M:\Lossless\Uber\Lazaridis, George-Emmanuel\Liszt Sonata and Etudes\7 - Grandes Etudes de Paganini Etude VI.flac'
      Error initializing FLAC encoder. [clEncoder::BeginConversion]
      Note, however, that I can successfully transcode to WAV format keeping all default settings. So, it seems that the FLAC codec is problematic. So, I uninstalled everything and re-installed. Same failure.
      Jim
      Configuration:
      dBpowerAMP Music Converter
      Release 12 Beta 4
      Registration Status
      Reference: Trial (21 days remaining)
      All Media Guide: 30 Days Access Remaining
      dBpowerAMP Audio Player
      Audio player extraordinaire
      dBpowerAMP CD Writer
      Audio CD burning simplicity
      Sveta Portable Audio: Unregistered Trial
      Release 5
      • Deano
        • Jan 2006
        • 130
        Sounds like you haven't ionstalled the R12 FLAC codec....
          To clarify what Deano said, did you install the FLAC codec from the dMC r12 beta thread or from Codec Central? You must use the r12 version, NOT the codec central version, as r12 has a new codec system.
          • jhenderson01075
            • Oct 2004
            • 12
            I did install the new FLAC codec along with the WMA v9 codec listed on the same webpage as the r12 dMC beta. That's not the problem.
            I have since learned that the problem lies with the specific 24-bit, 88.2 kHz WMA source files. 16-bit, 44.1 kHz WMA files can be successfully transcoded. However, the FLAC codec errors out during the conversion of the 24-bit, 88.2 kHz files.
            I know that the 88.2 kHz 24-bit WMAs are viable, because dMC can convert these WMA to WAV format and they play ok. This must be a limitation of the new FLAC codec for r12.
            For reference, I downloaded the studio tracks from:
            http://www.linnrecords.com/recording...nini-sacd.aspx
              The FLAC codec might not like the 88.2KHz. Try making a 24-bit 44.1KHz WAV file and then try converting that to FLAC. Does that work?
                Use the Resample DSP to set 44.1khz
                • jhenderson01075
                  • Oct 2004
                  • 12
                  88.2 kHz...
                  The 88.2 kHz was in fact the source of the problem. Using the DSP resampler, transcoding worked perfectly.
                  However, is this restriction somehow endemic to FLAC, or is it merely a restriction of the current implementation of the encoder?
                    Re: 88.2 kHz...
                    Many encoders don't like odd sampling rates. They expect 44.1KHz or sometimes 48KHz. That is probably the source of the problem.
