problems starting up
  • Han
    • Oct 2002
    I just downloaded and installed your decoder in order to convert some of my wma files into wav for using on websites. But whenever i start up the program I get the message: "cannot find entrypoint of procedure WMCreateSync Reader in DLL file WMVCore.DLL". What is wrong?
    I am running Windows 2000.
    Please help? :confused:
    Regards, Han
  • c15892
    • Oct 2002
    I'm having the same problem. I'm trying to convert a ton of .wma files to .mp3 and anytime I go to run any of the illustrate apps, I get that same error.
    Please help.
    Brian
      Have you installed the seperate WMFDist driver? (link under the WMA download)
      • vittoller
        This programme looks to be the answer to my problems . But I have just downloaded tonight and get the same error message as han, and I could not find the seperate WMFDist driver? (link under the WMA download) that you refer to
        help please
        • Han
          • Oct 2002
          Sorry guys,
          took me a while to answer to my own problem, but it has been solved for me.
          I installed the WMA V7 from the WMA link and everything is working just fine!
          So just got to the programs DMC configuration, doubleclick the WMA link and download and install your proper version -see Older Releases-.
          Good luck !
          PS Like the program very much!!:D
            Have a look again on the WMA Codec download page, there are two downloads that need to be installed to give WMA 9 support.
