Problems with dbPowerPack
    I've registred dbPowerPack and when I open SvetaExplorer ( to transfert MP3s to my MP3player ) i get this message :
    The 'Power Pack' needs to be installed to run this program, visit www.dbpoweramp.com to install.
    the problem is, powerpack is already installed !
    please help me
    • 46228
    Make sure you have installed it to the same place as Sveta
      i've reinstall it in the same directory and I get the same error message.
        • 46228
        Run Start >> Programs >> dBpowerAMP Music Converter >> Configuration >> dMC Configuration
        It will tell you the status of the Power Pack.
          it says :
          Power Pack : release 2
          registred : Yes
            • 46228
            Install the Power Pack release 3.
              I uninstalled power pack release 2 and installed release 3,
              i got the same problem
                • 46228
                Mail me at dbpoweramp@dbpoweramp.com with the name used to register and I will issue a new power pack.
                  even with the demo version i get this message...
                    • 46228
                    If a warez version has been installed then you are on your own...
