Problem converting from .mpc to .wav
  • paques82
    • Sep 2006
    I get a .wav converted file full of distortions :blush: . I used the MusePack Code Release 5 (Using SV7 mppenc 1.15v).
    Can anybody give me an explanation?.
    I would appreciate any indication of the reason behind this problem of distortion.
    Thanks for your help.
    :komisch9:
    paques82
    Re: Problem converting from .mpc to .wav
    What mpc setting did you use for encoding (if you don't recall, check tag for frequency, bitrate and channels)?
    What setting did you use for wave (frequency, channels and whether PCM or ACM)?
    Do the mpc files play OK?
    Will they test convert ok? (This is done the same way as a regular conversion except that where you select wave or musepack as your output file, select Test Conversion (No Write)).
    If you have Power Pack, have you tried switching conversion priority to Below Normal (set in the window that displays the progress of your conversion, but only if you have Power Pack)?
    Do you have Professional Frequency Conversion enabled? (Set in dMC Configuration).
    If the suggestions do not help, please post the specifics for your mpc files, your wave settings and the results of the suggestions you tried and what the results were.
    Bill
