monkey audio conversion error
  • Ssa
    When trying to convert .ape files made with v3.95 of monkey audio, the following error occurs:
    'The exception Integer division by zero.
    (Oxc00000094) occured in the application at location 0x0182e45c'
    I'm running Win2ksp2, dMC release 8d, with release 5 (using monkeys 3.92) of monkeys codec.
    Do I need to update monkeys codec (and how/where)?
    Thx.
    • 46228
    I will release a 3.96 just as soon as the SDK is available.
    • Ssa
      thanks for the link.
      still doesn't work, it's based on v394b2, my files are all done with v395. but i do get a different error message:
      CODEC decompression error for '*.ape'
      Error whilst running DSP effect, lack of disk space?
      guess i'll have to wait for monkey to release the v396sdk.
      thanks for a trully wonderful program though. really a time saver.
      • MODatic
        • 230
        Can MA 3.96 Stable (offical prog) decode it?
        I hope going to 3.96 will help you out but don't be disappointed if it doesn't, 3.95 alpha 1 was supposed to be a early unsupported (as in by later versions) version of MA.
        [COLOR=red]*MODatic crosses fingers[/COLOR]
        Cheers,
        [color=Blue][b]MODatic[/b][/color] :)
        [url=http://www.modatic.net/]modatic.net[/url]
        • Ssa
          ma v3.96 works fine, decodes everything.
          i've converted several files to v3.96, and release 6 of spoon's ma codec is still not able to read/convert it. so it's not the problem with v3.95.
          i'll wait for a v3.96 based codec. i'm guessing spoon really likes ma format, so we won't wait too long for it after the sdk is released .
