.ac3 Problem
  • Enzo24hrs
    • Apr 2006
    .ac3 Problem
    I have installed Direct Show Decoder and ac3 filter from the site and added the .ac3 in notepad but .ac3 to wav conversion goes on and on with no progress...time just keeps going. I've checked configuration and .ac3 shows installed. Anybody know why not working?
    Thanx
  • gameplaya15143
    • Sep 2005
    • 276
    Re: .ac3 Problem
    can you play the ac3 file in WMP (or any directshow player of your choice)?
    • Enzo24hrs
      • Apr 2006
      Re: .ac3 Problem
      It does not play in WMP...and does on another computer of mine that dbpower also works on. Something seems to be conflicting with the codec/filter i am guessing. Any known issues with Nero 7 or other programs...or different codec other than directshow decoder and ac3filter?
      I am able to convert from mp3 to wav and wav to mp3 fine. Cannot get ac3 to convert to wav or mp3...just stops progress immediately and time keeps running...have to force program to close.
      Thanx for any feedback!
      -enzo
