converting CD to Wav; crackling sound
  • dyet
    • Jul 2004
    • 35
    Hi
    I am using the converter to make some wav files from my CD.
    After the conversion when I play the wav file I am getting crackling sounds on the file.
    However, if i use other progs to do the program like Jet Audio or WinAmp. No crackling sounds.
    Any suggestions on what settings I would have to change?
    Dave
    Re: converting CD to Wav; crackling sound
    Are you using dMC Audio CD Input? or dMC alone from Windows Explorer?
    • dyet
      • Jul 2004
      • 35
      I am using dMC Audio CD Input.
        see here: http://forum.dbpoweramp.com/showthre...light=DMA+mode
        Also, try setting the communication to "Windows Built-In (Limited)" which is found by clicking Options, the "Advanced" button next to the CD Drive selection.
        • dyet
          • Jul 2004
          • 35
          Hi
          Tried the DMA thread, it said on my controller "DMA if Available" so i am assumming that's fine. So I left it alone.
          I installed the Nero Speed and changed it to maximum.
          I rebooted
          then re ripped a different CD and still the same crackling noises...I tried Jet Audio and I am getting no crackling.
          I tried "try setting the communication to "Windows Built-In (Limited)"
          re-ripped and still getting crackling.
          Thanks for the continued help
          Dave
            Are you using WIndows 98 ? If so there is something extra that needs to be installed. http://www.dbpoweramp.com/Windows95-Update.htm
            The cd may be copy protected. Disable table of contents detection, it may help.
            • dyet
              • Jul 2004
              • 35
              I am running....
              Windows XP Pro/Intel Pentium M 1700MHz/1GB ram/ ATI Mobility Fire GL T2/
              The cd isn't copy protected..
                Does it do it on any CD or just on one particular CD or on a particular group of CDs? What is one such CD that does this?
                • dyet
                  • Jul 2004
                  • 35
                  When I run (rip) dbPoweramp Conv. the crackling noise is on any cd.... (for example; I have ripped Steve Hackett - To Watch the storms, Steve hackett - Darktown.) I get the crackling.
                  When I run (rip) JetAudio or WinAmp on any CD..(for example; I have ripped Steve Hackett - To Watch the storms, Steve hackett - Darktown.) I don't get any crackling.
                  It just seems to be coming from dbPoweramp.
                    Make sure no DSP effects are running, some effects such as increase volume would cause crackling if setup wrong.
                    • dyet
                      • Jul 2004
                      • 35
                      Excellent
                      ...that was it (DSP Effects) it was on 'Normalize' I deleted it and everything worked fine.
                      Thanks for everone's help!
                      Dave
