Problems converting a single FLAC CD to...anything.
  • Vash63
    • Mar 2006
    I have a whole collection of FLAC CDs that I'm trying to convert to OGG...but a single CD's worth doesn't work. It outputs a file 3x longer than whatever I input, which plays at 1/3 speed. This happens regardless of which codec I output to, even WAV. However, the same issue does not happen in Foobar...but Foobar takes way longer to encode so I'd like to do it in dMB if possible.
    Re: Problems converting a single FLAC CD to...anything.
    Double-check the frequency of the FLAC files and the OGG files and make sure they are the same. Also, are your FLAC files 16-bit or 24-bit?
      Hold the mouse over each file (before and after), what are the frequencies?
