Alright, i was talking with a friend about converting MP3's from 192 to 320 and ripping CD's to 320.
He mentioned that if you convert any MP3 from any bit rate to any other bit rate whether it be 128 or 320 it loses quality no matter what.
He also said that if you rip from CD to 320 directly you get the best quality.
I also debated the fact that if you rip a cd into an ISO, BIN, RAW or any other image format and load it onto a virtual drive and then rip the tracks from there you might get better quality.
Im not sure what to do I have many MP3's and are now debating on whether i should up convert my 192 to 320.
Im using latest (stable) DBpoweramp CONVERTER with latest Lame Encoder.
Can anyone help me out here, would greatly appreciate it.
~Ozzie~
~Ozzie~
