Hello there,
Before you ask, yes, I have read this.
I have a burned CD here, I downloaded it in ISO format, it is a DTS 5.1 album which was ripped from a quadrophonic LP. I don't have a quad LP record player, or the LP, or a DTS system. I do however have a 5.1 soundcard with surround sound speakers (and the corresponding stereo version on CD, for those worrying about copyright issues
). It only seems to play white noise, which through searching I have found out is the standard response when you don't have a DTS decoder.
So I am hoping to rip these files to 6-channel WMAs. When I try with dbpowerAMP, it says that the codec cannot be opened. I know for certain that I have the codec installed, and it works when I rip the album in stereo. But then all I get is white noise!
So is there any way to fool dbpowerAMP into thinking it is a 6-channel CD? Or are there other codecs that can encode surround sound content? I couldn't see any. Even 6 mono wave files would be fine, but again I only get stereo white noise. So any ideas?
Thanks in advance for your help, and for reading through all of this!
). It only seems to play white noise, which through searching I have found out is the standard response when you don't have a DTS decoder.So I am hoping to rip these files to 6-channel WMAs. When I try with dbpowerAMP, it says that the codec cannot be opened. I know for certain that I have the codec installed, and it works when I rip the album in stereo. But then all I get is white noise!
