Audio CD Input is better than CDex
  • hellogator
    • Jan 2006
    • 12
    I have been using CDex for several years, but I just purchased dBpowerAMP Music Converter - Audio CD Input because of a bug I found in CDex. When I choose Track Offset, it didn't save the adjusted track number. So now I'm using dBpowerAMP Music Converter - Audio CD Input and it saves the correct track numbers, so I'm thrilled.
    I did find two features that appear to be missing, or perhaps I need to configure.
    #1. When I convert a track to mp3, the folder.jpg, AlbumArt_{xxx}_Large.jpg, AlbumArt_{xxx}_Small.jpg, and AlbumArtSmall.jpg are not downloaded from the remote freedb.
    #2 The Eject CD button does not toggle to Load CD.
    If you could please help me with this, I would greatly appreciate it.
    Re: Audio CD Input is better than CDex
    >remote freedb
    Freedb does not have any album art, perhaps you had other scripts?
    • hellogator
      • Jan 2006
      • 12
      I see that CDex uses CDDB instead of freedb. Apparently, CDDB has album art and it is downloaded automatically. Is there a way to connect to CDDB, instead of freedb?
        Sorry, no. dBpowerAMP works only with Freedb.
        But see this: http://forum.dbpoweramp.com/showthre...highlight=CDDB
          Also, dMC need to support album art in order for it to be downloaded.
