Tif conversion does not seem to work?
  • jrmach
    • Apr 2011
    • 39
    Tiff conversion is not working for me. If I try to convert any image file type to tiff none of the 4 conversion settings create a readable file.
    Re: Tif conversion does not seem to work?
    If you convert to a different format it works?
    • jrmach
      • Apr 2011
      • 39
      Yes the other conversions work only tiff does not.. It converts the file to a tiff but the file is unreadable by any graphics program... Other tiff files I have from other programs read fine.
        It is working for me, lets find out what might be different. Windows or OSX?
        • jrmach
          • Apr 2011
          • 39
          windows 10 64 bit, version 1909 (OS build 18363.900)
          • sahrenity
            • Aug 2020
            Hmm strange. I'm also on windows 10 64 bit but everything is ok
