Ripping using AIFF - can I select VBR rather than CBR?
  • CheshireChap
    • Mar 2022
    • 20
    Hi all - please don't pile on if this has been answered elsewhere, as I've tried looking back through and nothing matches what I'm looking for - I think!
    I work on a Mac, and rip at lossless AIFF. I'm not bothered about saving space so basically want the most accurate rip possible. From what I can glean on various forums, VBR presents the best possible audio quality over CBR - but I can't see any option to select VBR with ripping using AIFF. The only options I'm seeing for ripping are Bit Depth, Sample Rate and Channels, all set to rip [as source] - I can't see any other option screens, so not sure what I'm missing.
    I'm on Mac, Sonoma 14.4.1, dBpoweramp version 2024.04.01
    Thanks all.
    • 46119
    Re: Ripping using AIFF - can I select VBR rather than CBR?
    AIFF would not have CBR or VBR for lossless it does not need them.
    • CheshireChap
      • Mar 2022
      • 20
      Morning Spoon! Thanks for coming back. So when I see CBR as the encoded Bit rate mode, I can just ignore that?
        • 1629
        VBR (Variable Bit Rate) is only possible with compressed audio, where individual segments of audio data can take more or less physical space in a file, depending on their actual complexity.
        AIFF format holds uncompressed audio, therefore it can't possibly be VBR - ratio of file size to stored duration (Bit Rate) cannot change in mid-file.
          • 46119
          You can upload a screenshot of the encoder settings page please, upload to:
          Free image hosting and sharing service, upload pictures, photo host. Offers integration solutions for uploading images to forums.
          and paste a link please
          • CheshireChap
            • Mar 2022
            • 20
            Thanks Peter - I noticed that my FLAC files are encoded with VBR, so I wasn't sure if the same thing was possible with AIFF, but if it's a compressed audio file only setting, then I don't need to worry about it. Thanks for your help.
