Insert Audio CD
  • amkelly0814
    • Jan 2023
    Insert Audio CD
    DbPoweramp keeps saying &*8220;Insert Audio CD Into:&*8221;
    In my case I: is the DVD drive and there is a DVD already in the drive with music on the DVD.
    Why can&*8217;t it recognize the disc?
    For clarification&*8230;..when I insert a regular music CD (store bought) , then dbPoweramp sees it fine. (And Rips it also) But when I put in a DVD-R &*8230;no luck&*8230;
    Can someone explain the difference or how I can fix this?
    • 46198
    Re: Insert Audio CD
    Is this?:
    Microsoft have updated Windows Defender to include an option called "Controlled folder access" this basically limits every program from accessing key areas of the system unless permitted on an individual program basis. By default this option is off for Windows, however if it is enabled you should add the programs
    • amkelly0814
      • Jan 2023
      Re: Insert Audio CD
      Thanks. But this did not help.
      I do not use Windows Defender&*8230;.when I follow the thread and instructions provided there is no &*8220;Manage Settings&*8221; button.
      In any case I use Norton 360..and I could not find any issues with Norton controlling the dbPoweramp folders.
      As mentioned dbP sees the drive and reads the CD if it&*8217;s a old school audio CD , but not a DVD
        • 1914
        Re: Insert Audio CD
        CD Ripper is for ripping Audio CDs (red book standard), not for DVDs.
        • Michael Sargent
          • Dec 2009
          • 135
          Re: Insert Audio CD
          You need DVD Audio Extractor:
          Mike
          • GBrown
            • Oct 2009
            • 422
            Re: Insert Audio CD
            What format is the music on this DVD? If they are already in a music file format (FLAC, ALAC,mp3, etc.), you can simply just copy these as data files. If these are DVD-Audio or even SACD format, you will need a different solution.
