Error: Silence track detected, ReplayGain track tag not generated, track gain 0.00dB
  • DaveKiddle
    • Mar 2023
    Hi, fist post here. I'm trying to rip a CD and getting the following error. Can anyone please tell me what's going wrong? Many thanks
    Track 1: ERROR Ripping LBA 16777209 to 18278 (335:36:43) in 0:00. Filename: \\rock\data\Storage\CDs\Bruce Springsteen\Darkness On The Edge Of Town\01 Bruce Springsteen - Badlands.flac
    Silence track detected, ReplayGain track tag not generated, track gain 0.00dB [clDSP::EndConversion]
    • 6189
    Re: Error: Silence track detected, ReplayGain track tag not generated, track gain 0.0
    Looks like you are ripping to a network drive. Try ripping to a local drive on your computer. Do you still get the error?
    • DaveKiddle
      • Mar 2023
      Hi Gary, thanks for the reply. I'm not sure that's the problem as the rest of the album ripped OK. It's strange as the track is being listed as having a time of 335.36.43 - not sure if that has any bearing?
      Edit: Tried ripping to desktop, still the same issue.
        • 6189
        yes, that's not likely it, given other tracks ripped ok. Something very odd with the extremely high length yet silent. Do you have another drive you could use for ripping? Just as a test. Also clean the CD itself just in case. I've ripped 1000s of CDs and not seen this problem. Hopefully other folks might have some ideas.
          • 46198
          The CD has an invalid TOC, the first number cannot be bigger than the 2nd number. Is it copy protected?
          • DaveKiddle
            • Mar 2023
            Unfortunitely I don't have another ripping drive, and I've cleaned numerous times. The track plays fine on my CD player.
            This is what I see in the ripper:
Name:	Screenshot 2023-03-06 143350.jpg
            • DaveKiddle
              • Mar 2023
              Not sure, how can I tell?
              • DaveKiddle
                • Mar 2023
                [ATTACH=CONFIG]3529[/ATTACH]
                Apologies, incorrect image uploaded. here's the correct one:
                  • 46198
                  Try CD Ripper options >> select 'Defective by design', revert to Secure ripping mode after trying for that one disc.
                  • DaveKiddle
                    • Mar 2023
                    Yep, that worked, thank you so much. Fantastic program
